Ac Not Blowing cold
Old May 22, 2020 | 04:43 PM
cedric green's Avatar
cedric green
Default Ac Not Blowing cold
I have a 2001 dodge ram 1500 5.2 and I have been having issues with my Ac for a while and with this louisiana summer heat its unbearable. But so I checked my freon and is shows its full and is at the correct level the ac compressor does kick on and when I fill the cold side ac lines they are cold so it seems like something is working but the cab just isn’t getting cold air , now ik the blend door is s issue on this truck but I replaced that a while back and the blend door is definitely operating properly . now only days its not that hot like low 80s and 70s u can definitely fill a tiny bit of air but it’s nowhere working properly to keep the cab nice and cold
Old May 22, 2020 | 05:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Does your fan work on all 4 speeds?
Old May 22, 2020 | 06:16 PM
cedric green
Yes it does
Old May 22, 2020 | 06:31 PM
What did you do with the blend door? Are you getting good airflow thru the vents?
Old May 22, 2020 | 07:12 PM
cedric green
the blend door lil plastic cylinder was cracked at one point preventing ot from turning and opening the door when change the settings so I replaced it with the a company that makes a metal one as a replacement and I also replaced the blower motor resister so all settlings work now and the air flow changes through all levels
Old May 22, 2020 | 08:33 PM
There have been occasions where the blend door has actually broken away from the axle, so, it *looks* like things are working, but, they aren't..... Did you re-sync the little stepper motor when you installed the new coupler?
Old May 22, 2020 | 09:14 PM
cedric green
yes I did reset it and even before I fix the blend door I could manually open and close the door yet my ac still wasn’t working at the time
Old May 23, 2020 | 08:43 AM
Air goes thru the evaporator core first, then thru the heater core, or bypasses it to some extent or other. If the a/c system is doing its job properly, then any air flowing thru the system will be cooled. Since it isn't cool coming out the vents though..... either the a/c system IS not performing as intended, or, the blend door isn't doing it's job properly.
