OEM crate engine ?
Old May 22, 2020 | 07:14 PM
POSram2001's Avatar
POSram2001
Default OEM crate engine ?
On the fence about just keeping this damn thing. I can’t find a truck that’s 4x4 out here for less than 10k with less than 230k or so and I’m talking trucks 17-15 years old.
Id consider a crate engine , my only worry is I can’t really find an OEM with stock hp. I have a rebuilt tranny that runs fine but I don’t know how many miles is on it and how hp it can take.
the crate engine on summit with iron heads has 320 hp which is a lot more than factory power. I’d be really hesitant about running that much power on the tranny.
i can either dump the money for a new tranny from monster or dr evil or .... try to find an oem engine.
does anyone know where I find something close to stock hp so I don’t burn my transmission up ?
Old May 22, 2020 | 08:07 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Junkyard and then rebuild it to factory specs
Old May 22, 2020 | 08:29 PM
Jasper probably sells one as well.
Old May 23, 2020 | 07:30 AM
HeikIlm's Avatar
HeikIlm
I think you should be fine with 320 hp engine. It's just 75 hp over stock (just shy from 1/3 of the stock hp ), and you could install a shift kit to your trans to make it handle the extra power.
Old May 24, 2020 | 10:54 AM
Moparite's Avatar
Moparite
I did a search on there and none of the engines list HP. What where you looking at?
https://www.summitracing.com/search/...sabegi57vd_bwe
