96 Dodge Ram 5.9 gas
Old 05-29-2020, 01:03 AM
dcrews101's Avatar
dcrews101
dcrews101 is offline
Default 96 Dodge Ram 5.9 gas
So I知 wanting to put a a turbo on my 96 5.9 gasser and I知 wanting to know what injectors and fuel rails I should get.
Old 05-29-2020, 08:45 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,393 Likes on 3,133 Posts
Depends on how much boost you want to run. You will also need a new map sensor, (that can actually read the boost) and the appropriate programming for the PCM as well.
Old 06-08-2020, 12:57 PM
dcrews101's Avatar
dcrews101
I知 gonna be running about 18 psi I think
Old 06-08-2020, 02:26 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
18PSI will not run on a stock engine (at least for long if any)
Old 06-08-2020, 02:47 PM
HeyYou is offline
Yeah, I think about 7 to 10 is the max you can do without getting serious with the bottom end.
Old 06-08-2020, 08:27 PM
MoparFanatic21
According to what I read and seen (when I say seen I mean like 2 5 minutes YouTube videos) 10 is maximum
Old 06-08-2020, 08:28 PM
HeyYou is offline
Personally, I think 10 would be pushing it.......
Old 06-08-2020, 08:39 PM
MoparFanatic21
Absolutely if I planned on keeping it like that I would run 6-8 psi but then again I never played it safe before
Old 06-08-2020, 08:41 PM
HeyYou is offline
Good judgement is a consequence of experience. Experience is generally the consequence ob bad judgement. I am a PRIME example of this.
Old 06-08-2020, 08:44 PM
MoparFanatic21
I like to find the boundaries. For example I know a Chrysler 9.25 will take a lot of abuse, but apparently power braking it for 8 minutes while you are leaking gear oil out of the pinion seal and running low will trade it out. I was told that but now I know
Quick Reply: 96 Dodge Ram 5.9 gas
