Hard knock after oil change
Hey, I have a 2001 Dodge Ram 2500 24v 5.9L with P-Pump. new to this forum thought I would give it a try. Anyways before the oil change there was no knocking at all but now there is a loud knocking sound coming from the engine area. I put 15w-40 so it’s a heavier oil I’m not sure why it would be doing this? Maybe a noisy lifter and the oil just needs to get worn in? What do you guys think. Also I just bought this truck so I’m not sure if this has happened at any other oil changes.
Did the knock start immediately after the oil change? I changed the oil in an early 2000s Grand Prix one time and used a wix oil filter. Apparently it was defective because the engine started knocking immediately and didn’t smooth out. Unscrewed the filter and put a new one on and it went away instantly. Just a thought and worth a try.
If the knocking sound started after the oil change. Try removing the filter and inspect for any oil in the filter. If no oil. Fill the filter with oil and install back on. You may have loss the oil pump prime.
