Hesitation upon acceleration?
Old Jun 9, 2020 | 08:48 AM
Liddlez's Avatar
Liddlez
Yep, tighten to 72 INCH pounds, then back 'em off two turns each. Or, back 'em off enough to give a 1/4 to 1/2 inch gap.
So, does the engine rev, and the truck just doesn't move?
Basically I start her, shift her, and she doesn’t move. I press the gas, she revs, but doesn’t move. I de-press the gas, then she’ll start to move.
Old Jun 9, 2020 | 08:58 AM
Liddlez's Avatar
Liddlez
The best example I could give you is this. A movie clip from the film “Christine”
at 2:21.
Old Jun 9, 2020 | 09:53 AM
racefan41's Avatar
racefan41
I think your truck needs an exorcism, not a band adjustment
Old Jun 9, 2020 | 02:42 PM
If it only does it first thing in the morning (or, first drive of the day) It's probably just because the check valve is gone. (and good riddance.)
Old Jun 9, 2020 | 03:30 PM
Liddlez's Avatar
Liddlez
where would this check valve be?
Old Jun 9, 2020 | 03:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Lower transmission cooler line going into the radiator
Old Jun 9, 2020 | 11:22 PM
true blue's Avatar
true blue
I see the obvious genius that is, this man's diagnoses. Shut your pie hole. THAT'S IT!!! The pie hole...It's rite next to the kanutter valve on the disgronificature assembly! A blind man could see it a mile away!
