1997 3500 with headlight issues
Old Jun 12, 2020 | 01:04 PM
dcuplover's Avatar
dcuplover
Default 1997 3500 with headlight issues
I have read through a bunch of posts as to why the switch screws up etc. What I haven't seen is which coloured wire(s) do I splice the relay into? Any help would be appreciated. Thanks
Old Jun 12, 2020 | 01:14 PM
HeikIlm's Avatar
HeikIlm
You can look the colors from the connector at the headlight.
Old Jun 13, 2020 | 07:30 AM
Moparite's Avatar
Moparite
Have you read this? The headlights are only half the issue. Usually the connector will show signs of heat/melting on both the headlight and running light leads.
Old Jun 13, 2020 | 01:12 PM
dcuplover's Avatar
dcuplover
I purchased a new molex because it had overheated. I see someone has been in there previously as they installed a new spliced in wiring/molex unit. It was all done in factory matching coloured wires. My truck was assembled a few weeks after the recall was done so did not qualify for the recall. If I have the lights on for a period of time I can feel the warmth in the wires. It is funny that they went through with installing a new pigtail but didn't do the one extra step of wiring in a relay. When I installed the new switch, I found that it doesn't allow the roof lights to be on at the same time the headlights are. It seems the contacts are not exactly placed right. If I pull out the switch partially the roof lights come on with the tail lights and dash lights (but no headlights). Pull it a bit further and everything goes out except the headlights come on (brake lights work all the time). What a pain in the ***....
Old Jun 14, 2020 | 08:06 AM
Moparite's Avatar
Moparite
That sounds like a cheap headlight switch, I had replaced mine like three times(cheapo from autozone) and then got sick of doing it so spent the money on a good quality switch and plug and no issues so far. You can put a relay in for the headlights and replace the others with leds. This will drop the amp load greatly going threw the switch.
Old Jun 15, 2020 | 06:04 PM
dcuplover's Avatar
dcuplover
I am trying to find which wire(s) I need to cut to insert the relay.......
Old Jun 15, 2020 | 09:10 PM
Get the heavy duty relay harness from LMC truck. It's plug and play.
Old Jun 16, 2020 | 12:11 AM
dcuplover's Avatar
dcuplover
I was looking at that. How are their switches? I was going to see why mine is screwed up so bad and try to fix it but sometimes it isn't worth the time and effort. Thanks
Old Jun 16, 2020 | 08:01 AM
No switches involved. It's just a harness that plugs into the current headlight connectors, and a couple relays. Hook a couple wires up to the battery, plug in the connectors, and you are done. Took me about ten minutes to install mine.
Old Jun 17, 2020 | 01:51 AM
dcuplover's Avatar
dcuplover
my switch, even though it is brand new, is working like crap. I might as well replace it again if I am installing the relays. How is the quality of LMC's switches?
