1999 Dodge Ram 1500 Break lights staying on
Old Jul 8, 2020 | 05:44 PM
Logan709's Avatar
Logan709
Default 1999 Dodge Ram 1500 Break lights staying on
So I have replaced the break light switch, relay, multi switch, and the fuse. Even with the switch unplugged the lights stay on. The only way for the break lights to go off is to in plug the fuse under the hood.
Old Jul 8, 2020 | 05:45 PM
All the time? Even when ignition is off?
Old Jul 8, 2020 | 09:06 PM
Logan709's Avatar
Logan709
Yes sadly I think the harness has burnt up and melted something.
Old Jul 8, 2020 | 10:04 PM
Time to start tracing wires.......
Is it the brake lights, or the running lights that are staying on? Headlight switches were notorious for melting down on these trucks.
Old Jul 9, 2020 | 06:54 PM
Logan709's Avatar
Logan709
It’s the brake lights.The running lights come on when the brake lamp fuse is pulled. I can try replacing the headlight switch. I also disabled the trailer lights completely. So unless I see something burnt in the headlight switch I believe the whole harness is fried.
Old Dec 31, 2020 | 09:28 PM
Matis Plante's Avatar
Matis Plante
Commente to be notify
Old Dec 31, 2020 | 09:30 PM
Check the brake switch then. Just unplug it, and see if the lights go out.
Old Dec 31, 2020 | 11:18 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
? Wrong thread?
Old Jan 1, 2021 | 09:59 AM
? Wrong thread?
No idea......
Old Jan 1, 2021 | 10:47 AM
MoparFanatic21
No idea......
It happens
