Overheating issue
Old Jul 17, 2020 | 09:23 AM
  #51
I don't know how hard it is to pull the cluster apart, and move the needle.... Never done it before myself, but, if you set it so it is at least close to accurate at normal operating temp, that should be good enough. Might wanna experiment on another cluster. Just pick one up at the junkyard.
Old Jul 17, 2020 | 11:07 AM
  #52
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Once you get to the cluster, it's 4 screws to take the front plastic off
Old Jul 17, 2020 | 11:16 AM
  #53
96albertaram's Avatar
96albertaram
Great idea thank you
Old Jul 17, 2020 | 11:17 AM
  #54
96albertaram
Ok. I guess I need to go junk yardin lol
Old Jul 17, 2020 | 02:38 PM
  #55
MoparFanatic21
I have to go to sometime this week lol
Old Jul 17, 2020 | 02:47 PM
  #56
96albertaram
Curious if this would actually work cause when the truck is off it goes back to zero like everything else.hmmm
Old Jul 17, 2020 | 02:49 PM
  #57
96albertaram
Old Jul 17, 2020 | 02:55 PM
  #58
It will likely still go back to zero. Be real careful when you pull the needle, that the shaft it goes on doesn't get away from you. Means you have to start all over again.
