Clutch issues 2001 Dodge Ram 3500 quad 4x4
Old Aug 6, 2020 | 03:46 PM
squiglysteve's Avatar
squiglysteve
Default Clutch issues 2001 Dodge Ram 3500 quad 4x4
Installed a new prefilled master and slave cylinder assembly. Heres the problem. Now the clutch slips and clutch doesnt engage until the pedal is about 2 inches from the top. Mind you this is a southbend dual disk clutch. It seemed as though when installed the slave cylinder there was a lot of preload on it. Is this normal. And the plastic strap was on it when installed. So whats the problem? Any help would be appreciated.
Steve
Old Aug 6, 2020 | 07:03 PM
How many miles on the clutch?
Old Aug 6, 2020 | 07:40 PM
squiglysteve
A little over 5k. South bend dual disk.
Old Aug 7, 2020 | 07:56 AM
Are the hydraulics not allowing it to engage all the way?
Old Aug 7, 2020 | 12:10 PM
squiglysteve
Clutch pedal all the way up it seems as though there is a lot of pressure on the slave cylinder yet. Rod to long? Wrong part? Is this hydraulic setup the same in a gas vs diesel? Im more than likely just sending it back and buy a setup from southbend. I see that the slave is adjustable on their setup. Over twice the price though.
Old Aug 7, 2020 | 01:06 PM
Can you re-compress the rod in the slave cylinder, and reinstall it, then let it expand out? Would also give an opportunity to see where the fork is at when it actually starts pushing against the pressure plate.
Old Aug 7, 2020 | 01:15 PM
squiglysteve
I will definitely try that. Dont think itll change anything but worth a shot.
Appreciate your time.
THANKS
Old Aug 7, 2020 | 01:30 PM
Yeah, its a real shot in the dark........
