AC vacuum line
Old Aug 9, 2020 | 03:17 PM
Packwood Digital's Avatar
Packwood Digital
Default AC vacuum line
Replaced my ac compressor today all went smooth but I only had cold air blowing from the windshield vents...
checked my vacuum lines and the infamous T fitting one was broken.
i threw some electrical tape on it to diagnose and that fixed it... for an hour.
what is the name of this vacuum line? I want to buy a replacement but can’t find the correct name for it..
picture Included
Old Aug 9, 2020 | 06:15 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
picture Included
I have never found it, and I tried.
Old Aug 9, 2020 | 06:28 PM
Packwood Digital
I ended up cutting it short and wrapping a little tape around the end then SHOVED it into the boot. It’s half the size but so far it’s been holding up all day...
im going to check a parts yard and see if I can pull one.
Old Aug 9, 2020 | 06:32 PM
MoparFanatic21
The common fix is to get a hose that the little hose fits in tightly and use that.
Old Aug 9, 2020 | 08:16 PM
Yep, this. Use a piece of rubber vacuum line to splice the plastic line back together. It's actually a permanent fix, until the plastic breaks somewhere else.....
Old Aug 9, 2020 | 08:46 PM
MoparFanatic21
Did you ever find the plastic line?
Old Aug 9, 2020 | 09:42 PM
Was I looking for it?
Old Aug 9, 2020 | 11:06 PM
MoparFanatic21
I thought a while back you said you were trying to find it. I think I member here wanted to replace all the lines with new ones
Old Aug 10, 2020 | 07:17 AM
When I need to replace lines, I just get the rubber/viton vacuum line from the parts store. The hard plastic was a bad idea in my opinion. It is guaranteed to fail over time.
Old Aug 10, 2020 | 01:59 PM
MoparFanatic21
See I was going to replace all my lines (since I even have the HVAC box out an they don't make the rubber hose small enough and was worried it might get sucked shut. I was also going to test the HVAC vacuum lines
