2001 ram 1500 mystery idle surge and dead spot
Old Aug 25, 2020 | 10:20 AM
Rossgm1's Avatar
Rossgm1
Put a new 180° thermo in and also had to do a tps bc of flooding in my region truck had to drive through 2 feet of water somehow cooked a tps but the problem is still there im thinking Iac next?
Old Aug 31, 2020 | 01:39 PM
Rossgm1's Avatar
Rossgm1
Still having the same problem not fixed anyone with ideas it’s appreciated
Old Aug 31, 2020 | 06:08 PM
Unplug the front O2 sensor, see if things improve.
Old Sep 1, 2020 | 12:50 PM
Rossgm1's Avatar
Rossgm1
weird note my up stream and downstream o2 sensors are on different pipes before the y because of a cat delete. This hasn't been a problem before and its ran fine like that I'm just wondering what the o2 sensor unplugging will do.
Old Sep 1, 2020 | 02:26 PM
If the sensor is bad, your truck will run better. O2 sensors have a variety of failure modes that make your truck run horrible, but, so far as the PCM is concerned, everything is fine... so, no codes.
