Truck won't shift gears
Old Aug 22, 2020 | 06:12 PM
Walter Hale's Avatar
Walter Hale
Default Truck won't shift gears
We have a 1999 ram 2500 2wd automatic that will not shift gears. It feels like the gear shift isn't connected to anything anymore. We can move the gear shifter from park to 1st but the linkage on the other side of the firewall doesn't move. Anyone have an idea of how to fix the issue?
Old Aug 23, 2020 | 08:39 AM
Did something break in the column??
Old Aug 23, 2020 | 09:37 AM
Walter Hale
Not that I know of.
Old Aug 23, 2020 | 10:43 AM
If the column shifter moves, but, the linkage underneath does not....... Somethin' ain't right. Block the wheels, crawl under the truck, and see if you can move the shift linkage by hand. (key off.)
Old Aug 23, 2020 | 11:16 AM
Walter Hale
Yes, I am able to move it by hand.
Old Aug 23, 2020 | 01:25 PM
Then something is definitely broke. May need to replace the column. So far as I know, individual parts are not available.
Old Aug 23, 2020 | 03:50 PM
Walter Hale
Ok, thanks for the info. I will look for a replacement column.
Old Aug 23, 2020 | 05:55 PM
Careful doing that. Airbags can kill.
