Help
Old Aug 23, 2020 | 08:53 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Shannon Wayne Sanfacon
Not at all I'm not mechanically inclined I just fixed things via YouTubeI could have sworn there's a carburetor on top of it though it says Holly and everything
Holly makes throttle bodies. If you can read instructions you can add the external regulator if that turns out to be the problem
Old Aug 23, 2020 | 08:57 PM
Shannon Wayne Sanfacon's Avatar
Lol I can read...so do parts house's have it?
Yeah, I would start with having the alternator tested OFF the truck. Take it from there.
Old Aug 23, 2020 | 08:58 PM
I'm getting to the point I almost want to sell it
Old Aug 23, 2020 | 09:01 PM
Well, you got it DIRT cheap, so, having a few interesting problems is to be expected.
Old Aug 23, 2020 | 10:05 PM
Yeah I understand...thank you for all your help
Old Aug 24, 2020 | 09:37 AM
Moparite's Avatar
Moparite
Problem is not the alternator, Alternator output is controlled by the pcm. First have the voltage checked at the battery(where you got the parts they should be able to test it for you). To see what code/s you have do the key dance...
http://www.allpar.com/fix/80s-codes.html
Old Aug 24, 2020 | 02:38 PM
It doesn't show me any codes....
Old Aug 24, 2020 | 02:39 PM
Disconnected the battery lately? (aside from when it was changed....) Does the CEL come on when you try and start the truck?
Old Aug 24, 2020 | 04:09 PM
I'm not sure what the CEL is but I was just told that it's my cap and rotor now my next question is how hard is that to change for somebody that is not mechanically inclined
