Help
Old Aug 24, 2020 | 10:38 PM
  #21
Originally Posted by Shannon Wayne Sanfacon
I'm not sure what the CEL is but I was just told that it's my cap and rotor now my next question is how hard is that to change for somebody that is not mechanically inclined
It's a right pain in the keester, just because of where it is. The parts aren't hideously expensive. Cap is held in place by two screws, which you can't see, and can only maybe touch...... Phillips head I believe. The REAL trick is getting the plug wires back on in the correct order. That is absolutely critical though. Cap is marked for number one cylinder, then just follow the firing order. A mirror might help.....
I take the air filter box off the throttle body, stuff a couple rags into it, and drop a piece of plywood from the radiator support, to the throttle body, I then lay on that, so I am almost, sorta, kinda comfy reaching back behind the intake to deal with the cap. (this is one of the reasons I bought a truck with the V-10.... Distributorless ignition, hence NO distributor cap to deal with. )
CEL is Check Engine Light.
Old Aug 25, 2020 | 10:08 AM
  #22
Shannon Wayne Sanfacon's Avatar
Thank you so much
