Help
I have a 96 Dodge 1500 v6.... About 2 days ago I was driving down the highway and my truck started pottering like it was wanting to die I did some research plugs and wires were changed it's still did not help the situation.... Any advice and thank you in advance
Yes yes check engine light is on and it is also overcharging I just changed the alternator and battery not too long ago either
I'm I'm not sure what you mean by how bad but it's charging about 16 volts or so
Ok, that's too high. And that's the new alternator? Any warranty on it?
If you have a volt meter, might not be a bad idea to test at the battery as well, and see what voltage the battery is seeing. The gauges aren't known for being incredibly accurate......
Trending Topics
I bought the truck for a hundred bucks 5 years ago and this is the only problem I've had with it I changed the alternator and the battery but this problem is making me crazy I was just told by a buddy of mine that it could be my fuel pump to is that accurate or one of the Jets in the carburetor
Fuel injected, so, no carb.
The overvoltage can cause all sorts of fun problems, including burning up fuel pumps. If replacing the alternator doesn't solve it, (might just wanna take it in, and have it tested... see if it works properly on a test bench.) then its likely the voltage regulator. Which, unfortunately, is in the PCM..... There IS a method to bypass it with an old style external regulator, but, that requires doing some wiring. You comfy doing that kind of thing?
