Pcm
Old Aug 24, 2020 | 10:17 AM
Irwin Billiot's Avatar
Irwin Billiot
Default Pcm
I have a 2001 ram 1500 5.2l, is the computer interchangeable with any other dodges? i also have a 2000 dodge dakota. they look the same, but have different numbers on them. can trying it out hurt? i just want to swap them to make sure i have the right diagnosis. i already replaced ...
i have already changed the...
- coolant temp sensor
- radiator cap
- thermostat
- flushed coolant system
- changed spark plugs and wires
- crankshaft sensor and cam shaft sensor (called something else but everyone seems to call it the cam sensor) - pickup
- ignition coil
- distributor and rotor
- fuel pump module
- throttle posititon sensor
- idle air control valve
- 3 of the sensor on throttle body forgot name of third one
Old Aug 24, 2020 | 10:40 AM
What seems to be the problem?
What engine/trans in the dak?
Old Aug 24, 2020 | 12:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
He has another thread where you told him it was the PCM.
Old Aug 24, 2020 | 12:11 PM
Wish folks would just keep these to one thread..... I can't keep track of multiples.
Old Aug 24, 2020 | 12:38 PM
MoparFanatic21
Only reason I know is I am slacking in the help department and an catching up with all the threads I didn't read and he was one of them. I agree with you though
Old Aug 25, 2020 | 11:06 AM
Irwin Billiot
intermittent stalling, randomly shutting down, then saying no bus. almost like its overheating but its not overheating. its likely a curse ; giving me a finite amount of time driving before it shuts down on me. only thing left to replace is computer. i think
Old Aug 25, 2020 | 11:29 AM
any codes? last time it had a tune up? What else have you done to try and fix it?
