RAM v6 3.9 liter (1998)
Old Aug 28, 2020 | 10:32 AM
CLPS's Avatar
CLPS
marks and lines...yebbut I'm being thorough
Old Aug 29, 2020 | 09:10 AM
Moparite's Avatar
Moparite
I won't forget No ! position at T D C
TDC #1 cylinder ON THE COMPRESSION STROKE! After you get this far remove the cap and see where the rotor is pointing. If memory serves me it should be pointing to the left(about parallel to the end of the block). If you can't position the body for the rotor to point to the mark the oil pump/distributor drive gear may be off.
Old Aug 29, 2020 | 05:20 PM
CLPS's Avatar
CLPS
Thank you, this the detail I really need right now.
