Misfire and torque converter clutch codes
Old Aug 30, 2020 | 09:08 PM
Better wires really isn't a bad plan. 8mm or better. You may not notice the engine runs any stronger, but, you are less likely to suffer from 'cross talk' from the plug wires, and firing the wrong cylinder at the wrong time. There was a technical service bulletin about plug wire routing on these with the stock wires, simply because of that particular little problem.
That, and I want as much of the energy to get to the plug as I can get.
Old Aug 30, 2020 | 09:13 PM
96albertaram's Avatar
96albertaram
Sweet. Ya I'll look into those seems like there is quite other companys trying to compete with msd.
Old Aug 30, 2020 | 09:24 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 96albertaram
What was the fix?
Mine was the plug wire fell onto the header and burned in half. I use 8mm wires because rock auto has them cheap
Old Aug 30, 2020 | 09:41 PM
96albertaram
no rock auto up here in canada EH lol. Seems like lots of companys make 8mm they all pretty much the same?
Old Aug 30, 2020 | 09:47 PM
MoparFanatic21
In my opinion yes
Old Aug 30, 2020 | 09:53 PM
96albertaram
In my opinion yes
Ok ya mSd your paying for the name. I'll just find a generic 8mm set
Old Sep 1, 2020 | 10:06 PM
96albertaram
Just an update everyone. I changed all the plugs and after connected the battery again. No codes! Pretty happy was easy fix. I got a nice drive this weekend to do I'll see If the codes come back
