ABS vs Non ABS axles fitment
Old Sep 1, 2020 | 06:55 PM
BlackAce's Avatar
BlackAce
Default ABS vs Non ABS axles fitment
Hey guys sorry if this was asked already. I searched and couldn’t find any exact info I’m looking for.
I have 01 1500 Sport without ABS in front. Seems as though I’m having a hard time finding non abs axles and if I do they are crazy money. I read that ABS axles with the tone ring will fit. My question is I’m doing my whole front steering, suspension and brakes and bought everything needed. Will a non ABS hub fit on an ABS axle?
Also I’m showing Mopar part number 501536AB and also seen this from 03-08. Will 03-08 axles work. My front axle is a Dana 44.
Old Sep 1, 2020 | 07:12 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No the axles won't fit as they are CV joints no straight axle. The hub should fit as all they did was add a tone ring to the back.
Old Sep 1, 2020 | 07:40 PM
BlackAce's Avatar
BlackAce
So for confirmation ABS axles will work with non ABS hubs? They look the same with just the tone ring added but I wasn’t sure if there was a depth issue.
Mopar is showing the same axle with that part number working from the late 90’s with a Dana 44 through 2003 - 2008 but superseded with a new part number for 2003-2008.
Old Sep 1, 2020 | 07:45 PM
BlackAce's Avatar
BlackAce
Correction from late 90’s to 2001 then superseded with a different part number from 2003-2008. Usually a superseded part number will fit just an updated part number for the newer years. Just like the upgrading to the newer track bars will fit but thicker but will fit with the same geometry.
Old Sep 1, 2020 | 07:53 PM
MoparFanatic21
2002 on the 1500s they used CV joints no straight axles. The 2500/3500s had straight axles but switched from DANA to AAM. It won't fit
Old Sep 1, 2020 | 07:54 PM
MoparFanatic21
Also the newer track bars aren't a direct bolt in, you have to buy a bracket
Old Sep 1, 2020 | 07:55 PM
MoparFanatic21
I am pretty sure the axles will work. The hubs are the same dimensions and like you said all they did was add a tone ring
Old Sep 1, 2020 | 08:54 PM
The ABS axles should work is what he is saying. 2002 and up 1500's are independent front suspension, and entirely different design from the Dana 44. Nothing from the newer trucks will interchange.
Old Sep 1, 2020 | 08:56 PM
MoparFanatic21
Thanks, sometimes I suck at explaining
Old Sep 1, 2020 | 08:58 PM
I understood it.
