Tow capacity
#31
Mud Sligger, what type of trailer are you pulling? You driving on the hiway? Do you have a trailer brake controller? If the pin weight isn't to heavy the truck will be ok pulling a trailer if you take your time at it (the truck will be slow anyways). 37in tires will kill your transmission regardless.
I own a 2001 5.2 1500 4wd 3.55 (32in tires) trucks as well, it is totally gutless but on flat land I probably could pull a dump trailer with total weight around 6000-8000 lbs, but it will not be fun. Worst thing will be stopping, so crank up the trailer brake response.
I own a 2010 3500 6.7L set-up for pulling trailers and has no issue pulling over 20000lbs
fyi- I hauled 2000 lbs of gravel in the 2001 bed, the truck was dead slow and took forever to stop.
#32
With no stickers how would any law enforcement know your legal towing capacity? As long as you are within reason you will be fine, a 5.9 with 3.55 gears is gutless when towing much more than 5K anyway so you probably wouldn't want to go over about 7K.
#33
