Help with misfire and bogging down
Old Dec 30, 2020 | 12:50 PM
  #281
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Goshdarnram
Yes everything works when I unplug the abs the brake light and abs light goes off and it’ll come on when I press the e brake and go off when I depress the e brake so the light works
Well since you have 4 wheel ABS you have 3 sensors. One in the diff and one running to each front wheel. Now on the rear wheel abs replacing the sensor in the diff USUALLY fixes it. But I have seen it to where someone installed the non and wheel bearing into a truck that needed the ABS one. Now you can try to ground pin 13 of the OBDll connector and the ABS light will flash the code.
Old Dec 30, 2020 | 01:00 PM
  #282
Goshdarnram's Avatar
Goshdarnram
Oh okay will do I think I might replace the sensor on top of the diff anyways new parts never hurt a 20year old truck in my opinion
Old Dec 30, 2020 | 02:25 PM
  #283
MoparFanatic21
No but be sure to get a Mopar unit or Standard Motor products
Old Dec 30, 2020 | 02:39 PM
  #284
Goshdarnram
Yup always do I’ll get the codes scanned first I didn’t know scanners could read abs
Old Dec 30, 2020 | 07:55 PM
  #285
MoparFanatic21
Has to be a high end scanner like snap on or similar
Old Dec 30, 2020 | 07:56 PM
  #286
Goshdarnram
Oh okay
Old Dec 30, 2020 | 08:00 PM
  #287
MoparFanatic21
Oh okay
I know on the 98 and down you can ground the obd2 connector and it will flash the codes
Old Dec 30, 2020 | 08:05 PM
  #288
Goshdarnram
Oh okay where will it flash the codes at?
Old Dec 30, 2020 | 08:09 PM
  #289
MoparFanatic21
The ABS light will flash the codes. So let's say it's code 23 it will flash twice a pause then 3
Old Dec 30, 2020 | 09:03 PM
  #290
Goshdarnram
Oh okay I will definitely try that
