Build 3605.9
Old Sep 17, 2020 | 11:20 PM
ThatRedRam's Avatar
ThatRedRam
can you send links to some pistons and rods thatll work together for the 5.9 360
Old Sep 18, 2020 | 06:34 AM
Moparite's Avatar
Moparite
Bigger question is how are you going to run it? It's a 95 (OBD1) no tuning available. ???
Old Sep 18, 2020 | 09:32 AM
Yeah, that is most certainly going to be an issue. Likely going to need an aftermarket engine management system to run it. Or, go carb.....
Old Sep 18, 2020 | 10:34 AM
ThatRedRam's Avatar
ThatRedRam
well the computer in the truck is for a 318 so hptuners has credits available for the 5.2 computer specifically for the 95. after i get the tuner you can change in there setting to a 5.9
Old Sep 18, 2020 | 10:55 AM
Mike Holmen's Avatar
Mike Holmen
Originally Posted by ThatRedRam
well i wanna get it ready for boost. I wanna get hypereutectic pistons. but idk what pistons and rods to get exactly could somone put links to some?
The magnum 360 already have hypereutectic pistons, just have a dish -4cc (just a guess). The stock pistons will hold up, its more a matter of tuning. If you have stuff messed up, no matter how good of pistons you buy, they will become scrap.
I would dump that factory fuel injection and buy anybody's aftermarket fuel system (way easier to tune). The best set-ups have injectors in the intake runners. I was thinking about running LA heads, as there are more intake choices. The only trick will be getting your transmission to like new EFI fuel system. I was going to plug in the TPS, map sensors back in. You might still have a check engine light. I have 85 corvette with a LS2 engine, running fast stand alone EFI system. Super easy to tune/tweak
Old Sep 18, 2020 | 11:43 AM
Link please? The stock computer is not flash programmable...
Old Sep 18, 2020 | 05:57 PM
ThatRedRam's Avatar
ThatRedRam
https://www.hptuners.com/products/
id like to just go carb i have a hole list to swap it over but my issue is the wiring and how to do that with getting rid of the computer
Old Sep 18, 2020 | 07:01 PM
Not seein' anything there for OBDI.......
Old Sep 19, 2020 | 06:50 AM
Moparite's Avatar
Moparite
They say this at the top "Vehicles that are only supported by MPVI2 are identified below by a (2) after the vehicle model type." they have a "95 Dakota 5.2 (2)" listed. ???
Old Sep 19, 2020 | 08:08 AM
Yeah, that seems really odd to me. Both vehicles are OBDI, which are NOT flash programmable....... Real curious how they get around that.
Emailed them and asked.
