Steering box brace
Old Sep 27, 2020 | 10:43 AM
96albertaram's Avatar
96albertaram
Default Steering box brace
Thinking of updating my steering and been reading about the steering box brace. Its the one that attaches each end of where the sway bar is and has a bearing where the pitman arm goes. Has anyone ran these and does it actually help with steering play? My only concern is when off road it not allowing slight frame twist
Old Sep 27, 2020 | 02:30 PM
Dodge Off-Road makes one that only mounts around the steering box, it's a nice piece, and allows the frame to twist a bit, to avoid exactly the issue you are talking about, but, it sure ain't cheap.
Old Sep 27, 2020 | 04:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I used the exact one you described and it did nothing
Old Sep 27, 2020 | 07:19 PM
ddtmoto's Avatar
ddtmoto
I put one of the ebay cheapie braces on mine. $55 or so. I had upgraded already to a Borgeson box and tie rods ends, drag link which made a huge improvement in the steering. I was impressed by results of the brace install. Noticeably tightened things even more. Well worth my time and effort...
Old Sep 27, 2020 | 07:45 PM
MoparFanatic21
That's the one I used and didn't notice a difference
Old Sep 27, 2020 | 10:27 PM
96albertaram
Ya I seen those there nice. Almost like a skid plate to. If it actually helps id say it may be worth the money. Im skeptical about the full brace style units.
Old Sep 28, 2020 | 12:46 AM
Ramman18's Avatar
Ramman18
I'm on the other side: not worth the money or effort. The play in your box will never be cured by a brace that was never designed for, nor intended, to be attached to the frame. Best option is get a good box like Redhead and never look back. I left off my brace and stabilizer. Solid box, 1 ton steering, and good alignment is all you need.
Old Sep 28, 2020 | 06:57 PM
96albertaram
Yah those red heads look nice but with the currency exchange its BIG money lol i might live with the slop for now unless the reman box gets shot again soon here ill consider it . I wanna do some other upgrades first maybe then.
