Hard start
Old Oct 2, 2020 | 10:53 AM
David schmunk's Avatar
David schmunk
Default Hard start
01 ram 1500 5.2L. Really hard start in the AM. Smells rich/ blue smoke while feathering gas to get running. Once warm, no probs all day. Have already ran diagnostic and no codes thrown. Replaced fuel pump, dist. Cap and rotor, coolant temp sensor. Out of options
Old Oct 2, 2020 | 11:53 AM
What does fuel pressure do when you shut the engine off? If you cycle the key a couple times, does it start easier?
I would be tempted to plug a scanner in, and see what the PCM thought engine temp was, first thing in the morning.... Sounds like it is getting too much fuel.
Old Oct 2, 2020 | 12:19 PM
David schmunk
Good fuel pressure. Cycling key does not help
Old Oct 2, 2020 | 12:21 PM
David schmunk
Default Hard start
Fuel pressure is good. Cycling key does not help. Thought about an online ball check, but with good pressure, decided against it
Old Oct 2, 2020 | 01:23 PM
Does pressure bleed off quickly after it primes?
Old Oct 2, 2020 | 02:01 PM
David schmunk
No, pressure dies not bleed off
Old Oct 2, 2020 | 02:04 PM
How do your plugs look, and what kind/brand are they?
If you just step lightly on the pedal, and hold it there, will it start any easier?
