3.9l headers
Old Oct 4, 2020 | 07:31 AM
HD Kowboi's Avatar
HD Kowboi
Default 3.9l headers
I have a 2001 ram 1500 with the 3.9l engine. I upgrade the throttle body to one from a v8, installed a 180 degree thermostat, upgraded the plugs and wires and run synthetic oil. I haven't installed a cold air intake yet. I also have a set of headers for it which I've had pretty much since I've had the truck. I recently got around to trying to put the headers on but first had to make a block off plate for the passenger side header. Apparently some kind of sensor which I don't have was supposed to mount on one of the runners. Then I started checking to make sure all the bolts would fit. The passenger side seems fine but on the driver's side the #2 and #4 bolt won't fit. The exhaust tubes are bent too sharply making them too close to the flange to get the bolt in. I thought about maybe using a couple of short studs in the block. What do you guys think other than get a v8.
Old Oct 4, 2020 | 09:18 AM
Can you start the bolts before any of the others are tightened down??
Old Oct 4, 2020 | 10:03 AM
HD Kowboi's Avatar
HD Kowboi
This what I'm looking at.
Old Oct 4, 2020 | 10:21 AM
Wow, that's just not going to work..... Can you even get the bolts into the holes???
Old Oct 4, 2020 | 10:31 AM
HD Kowboi's Avatar
HD Kowboi
Nope, that's the problem. Even if I put some short studs in there I could only get a couple threads on the nut. Clearly who ever designed these never installed headers before.
Old Oct 4, 2020 | 11:04 AM
Spillage's Avatar
Spillage
Slot that hole... start that bolt, then slide the slotted hole around the bolt, then install the rest of the bolts.
Old Oct 4, 2020 | 11:14 AM
HD Kowboi's Avatar
HD Kowboi
I thought about that as well.
Old Oct 4, 2020 | 02:07 PM
Spillage's Avatar
Spillage
Don’t be afraid to dent the tube to give yourself a bit more clearance... it doesn’t hurt performance.
Old Oct 4, 2020 | 05:05 PM
HD Kowboi's Avatar
HD Kowboi
Yup, I was hoping this was going to be an easy/pretty install based on how the passenger side looks but I'm gonna need a big hammer. They're shorty headers so who knows how they'll line up with the y-pipe.
