Neutral safety switch
Old Oct 12, 2020 | 09:47 AM
Originally Posted by Terribletim
The exploder I had wouldn't go into 4 unless I crawled under and tapped the transfer case, in the mud. So I just need to cap that red tube?
If you Permanently lock the cad, you don't need the vacuum system any more. However, it's a really simple system, and when properly maintained, works just fine.
Old Oct 12, 2020 | 10:17 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Agreed here but there is the potential for problems. Mine was always delayed and sometimes had to move the truck.
Old Oct 12, 2020 | 01:32 PM
Yeah, it isn't instantaneous by any stretch of the imagination, and it picks the absolute worst times to fail..... (which is why I test mine on a fairly regular basis...... ) But, no worse than any other CAD system I have used. At least it isn't like the older chevys, with there thermal actuator, which would disengage when it got snow packed around it.
Old Oct 12, 2020 | 05:01 PM
MoparFanatic21
I just set it up like my 3rd gen no CAD because I always forget to engage it before I get stuck
