Leaf spring helper help
Old Oct 27, 2020 | 07:47 PM
mud slinger's Avatar
mud slinger
Default Leaf spring helper help
Well my vehicle has lots of axle wrap and hops tires when ya floor it so I found that putting leaf helpers on the front would solve this, but the part that goes into to the eye of the spring doesn’t have the holes on the bracket high enough for the bolt to go through both sides. I could take off the plastic that comes with it that might help but it doesn’t something probably for squeaks, drill holes higher might affect his it don’t know. If y’all got any other ideas I’ll try em but I could find some way to press em together real hard and then it would work but all I got is vise grips didn’t work. I’ll probably work on it again tomorrow because it’s to tall for garages and skeeters real bad so it’s a daytime thing after I get off work so I got a few hours. So hopefully one of something works fast so I can drive it more and not drive very slowly all the time. Everything I ever do to a vehicle is never at simple as just getting the part and putting it on it’s always something else.
Old Oct 27, 2020 | 08:33 PM
How about a c-clamp??
Old Oct 27, 2020 | 08:37 PM
mud slinger
well you make a good point I’ll see if mine fit thanks
Old Oct 29, 2020 | 12:27 AM
Ugly1's Avatar
Ugly1
I just want to delete this message since it is in the wrong thread.sorry
Old Oct 29, 2020 | 01:19 AM
mud slinger
okay sounds good
Old Nov 26, 2020 | 08:33 AM
mud slinger
Welp the leaf helpers made it only hop the back tires when completely still before you could be rolling and they’d do it the ride got better more firm which I like. Offroad the rear feels a lot better, but still ya give it the beans from a dead stop you can watch the tire hop 3 inches off the ground. I guess there is no shortcuts and I’ll just have to get rid of the blocks and get custom leafs built for my lift and then it will be solved cause 6 inch lifted leafs have such a curve and I’ll get the good and stuff ones I don’t think Ill get wrap. And hey I’ll get more flex offroad.
Old Nov 26, 2020 | 08:59 AM
Consider a shackle flip along with custom leaves, that will have the springs with MUCH less arch to them.
Old Nov 26, 2020 | 01:56 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
A shackle flip will yield 5.75" if you keep the factory block or 2.75 if you get rid of it. The 3rd gens come from the factory like this, that's why they don't have blocks!
