01 Rear Brake Lines
Anyone have experience with the Lysle 33260 flaring tool? The HF that I used tended to collapse CuNi tubing, and worked better on steel. I returned the HF after the 3/16 dies broke the tip off twice. The 1/4 once.
On the vent hold down, heat and vibration are your friends. A dull chisel on an air chisel with very gentile trigger control seems to help the rust busting oil get in. The bolt you are reefing on is hollow. Take care grasshopper.
More familiar with this style, but, I suppose it's all just a matter of what you are used to. I have also seen them a LOT cheaper than 60 friggin' bucks.
