Truck runs great until it warms up
Old Nov 17, 2020 | 09:23 AM
  #21
You only have 10" of vacuum at idle? That ain't right. You should see at least 17"..... You have a pretty significant vacuum leak somewhere.
Old Nov 17, 2020 | 02:52 PM
  #22
DerTruck's Avatar
DerTruck
That's the reading from the manifold *absolute* pressure sensor, not a direct vacuum reading. MAP should read 29ish with the engine off, so there is about 19" of vacuum. Looks ok to me.
Old Nov 18, 2020 | 07:00 AM
  #23
You are quite right. Thanks for the correction.
Old Nov 19, 2020 | 12:29 PM
  #24
adukart's Avatar
adukart
Something is telling the truck it has more fuel than it does or that it has less air than it does. The only sensor you have not replaced yet that influences this is the MAP sensor. Since you were messing with vacuum lines make sure that it is routed so that none of the check valves are blocking the vacuum signal first but it sounds like you map sensor could be starting to fail. Other possibility is you have a new bad sensor. Also check all your harness's, make sure no critters thought the wires looked tasty..................
Old Nov 20, 2020 | 12:47 AM
  #25
David 0512's Avatar
David 0512
ok question, is the check valves directional? And if so how do I know which way they go?
Old Nov 20, 2020 | 08:46 AM
  #26
Yes they are. Should be an arrow on them pointing in the direction of flow. If there isn't, just blow thru it, that'll tell ya real quick.
Old Nov 20, 2020 | 02:38 PM
  #27
adukart's Avatar
adukart
They are directional but the vacuum feed to the map sensor should be unobstructed by any check valve no matter the direction of flow.
Old Nov 21, 2020 | 09:14 AM
  #28
Moparite's Avatar
Moparite
Check valves are for the line going to the reservoir/hvac controls.
if I apply any gas it'll raise the rpms up a little but it'll start to backfire and run very rough and it then die and I won't be able to start it until the next day and then the same thing happens
When it won't start you need to see what's missing, Fuel of spark.
