What was this bolt/stu for, can it be replaced?
Old Nov 14, 2020 | 08:43 PM
Liddlez's Avatar
Liddlez
Default What was this bolt/stu for, can it be replaced?
This nut was literally hanging by the last threads, I tightened it to what I thought was 50ft lbs, and tit snapped. It looks to be a stud. It had a double nut. Can I replace the stud? What was it for, am I screwed? Thank you!”.
Old Nov 14, 2020 | 09:13 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I think that is a bolt and nut for the coil bracket
Old Nov 14, 2020 | 09:15 PM
Liddlez's Avatar
Liddlez
I agree, but what’s REALLY strange is that this looks to be a stud with double nuts, while the others on other magnums seem to be bolts.
Old Nov 14, 2020 | 09:46 PM
If it is still holding the coil in place, just leave it. Probably something that got put in the wrong place with some other work going on.
Old Nov 14, 2020 | 09:50 PM
Liddlez's Avatar
Liddlez
I figured it out. Since the engine was originally for a ‘98 Durango, this was a ground hence the double nuts. The bottom mount also has two nuts.
Old Nov 14, 2020 | 09:51 PM
MoparFanatic21
Glad you got it figured out? FYI I think the torque is 50 inlbs not ftlbs :b
Old Nov 14, 2020 | 10:00 PM
Liddlez's Avatar
Liddlez
No, see my mistake was thinking that this stud was the pulley mount bolt, which is 50ft lbs.I checked it twice.
Old Nov 14, 2020 | 10:51 PM
MoparFanatic21
Oh yeah that will do it!
