Turn signal, brake lights out
Old Nov 17, 2020 | 12:27 PM
downunder's Avatar
downunder
Default Turn signal, brake lights out
Suddenly I don't have turn signals, hazard signal, or brake lights on 1999 Ram 1500. Fuses look good. Not sure which flasher/s or relay is the right one. I have looked in the PCM and the fuse panel just inside the driver's door. I'm stumped as to what would have caused these three things to go out at the same time. Thanks guys.
Old Nov 17, 2020 | 12:53 PM
There is a combination flasher in the fuse block on the side of the dash. It's at the lowest point in the fuse block.
Old Nov 17, 2020 | 01:09 PM
downunder's Avatar
downunder
Blue square box about 1 1/4"? ID diagram doesn't say what it's for.
Wife said she did not see brake lights yesterday (maybe the sun was in her eyes) but they are working at this moment. Should the combi just pull out I presume?
Thanks for your reply. Also, I found this thread that I'm going to keep handy- https://dodgeforum.com/forum/ramchar...t-working.html
Old Nov 17, 2020 | 01:11 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It looks like a relay, I believe mine was blue. It will just pull out but mine was tight. I used a mini flat head to pry up on the sides
Old Nov 17, 2020 | 05:48 PM
downunder's Avatar
downunder
So- no turn signal, no hazard signal. Brake lights do work. Pulled and replaced the combination flasher. Man that thing was in there tight but then it was the blue Mopar OEM unit. Maybe this will help someone else in the future.
Old Nov 17, 2020 | 06:23 PM
MoparFanatic21
So it's fixed?
