Water spot in lower left passenger side floor?
Old Nov 21, 2020 | 02:38 AM
Liddlez's Avatar
Liddlez
Default Water spot in lower left passenger side floor?
As soon as I got my air conditioner fixed, this started happening. It’s 100% not the heater core. But the funny thing is, my drain pipe (below the pcm) is draining. It’s definitely not the 3rd brake light as it hasn’t rained. Where could this leak be coming from? I know it’s from under the dash, but I don’t know where. Thank you all! I do apologize for the constant posts. I do try to figure things out before asking DF.
Old Nov 21, 2020 | 02:41 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Are we talking the driver's side?
Old Nov 21, 2020 | 02:43 AM
Liddlez's Avatar
Liddlez
Passenger.
Old Nov 21, 2020 | 08:19 AM
Moparite's Avatar
Moparite
It may be draining but the issue is the foam used to seal it(body to tube) deteriorates over time and allows it to come into the cab. Do a search for it, I know there are a few threads on it.
Old Nov 21, 2020 | 08:31 AM
Liddlez's Avatar
Liddlez
Did the search. Most were talking about the 3rd brake light, or door seals. Obvious places. I knew for a fact it wasn’t either of those as I’ve never experienced a wet floor before fixing my A/C. I took a look, and didn’t see evidence of water behind the dash, at the drain, BUT I did see water droplets above on the evap housing.
Old Nov 21, 2020 | 08:33 AM
I *think* what happens is, the drain points straight out, so, when you are moving, wind blows the water back into the truck. The fix is to put a 90 degree elbow on the drain.
Old Nov 21, 2020 | 08:47 AM
Liddlez's Avatar
Liddlez
I do hope that’s it. I would hate to have to modify something such as sealing with RTV. I’m headed to NAPA to purchase a 90° fitting another user talked about. Thank you so much! According to him, Dodge sold the fitting for $5 at the time, but I looked on eBay, and they want $23 for a vinyl looking tube!
Old Nov 21, 2020 | 08:57 AM
It's a 'special' vinyl......
