Fuel pump float keeps falling off?
Old Nov 22, 2020 | 11:11 PM
Liddlez's Avatar
Liddlez
Default Fuel pump float keeps falling off?
This is going to be the 4th time I drop my gas tank to reinstall the float on the arm. Does anybody have a suggestion what I can use to stop this from happening? Because apparently the slightest bump will knock the float loose. The fuel pump is a Delphi. Thank you all.
Old Nov 23, 2020 | 03:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It should have a washer and a river on the end to keep it from falling off
Old Nov 23, 2020 | 04:05 PM
Liddlez's Avatar
Liddlez
Unfortunately this one came with the snap on float. Not the riveted style float.
Old Nov 23, 2020 | 06:09 PM
Warranty it out, if you can. If you can't, replace it with a better quality unit.
