Transgo or Sonnax 3-4 accumulator spring
Old Nov 28, 2020 | 10:13 PM
Reaprr's Avatar
Reaprr
Default Transgo or Sonnax 3-4 accumulator spring
Just got the valve body out of my 2001 ram 1500 4x4 with a 46RE
Ive looked for a comparison of which would be better or are they the same for the 3-4 accumulator spring. TransGo calls the piston that the spring go into an OD accum piston, but everyone else says 3-4.
Maybe overthinking this.
Not sure which one i should use?
Thanks
Old Nov 28, 2020 | 10:36 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks
3 to 4 is OD
Old Nov 28, 2020 | 11:06 PM
Reaprr's Avatar
Reaprr
So which spring should i use the one with the transgo kit or the sonnax
Old Nov 29, 2020 | 09:24 AM
Probably the same spring...... Do they look similar?
Old Nov 29, 2020 | 10:37 AM
Moparite's Avatar
Moparite
It's the same, 4th is od.
Old Nov 29, 2020 | 07:19 PM
Reaprr's Avatar
Reaprr
yes, i ordered the parts from oregon performance transmission and there was an option for upgraded spring, so i said yes. They look the same when compared to eachother. ive put the sonnax in since ive already got it, and as predicted the spring was broke and im missing all the parts to the boost valve.
gonna order a kit tonight for it.
Old Nov 30, 2020 | 01:13 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Yup they look the same. I went with the Sonnax. Doesn't really matter which kit you go with. Did you find the missing parts?
Old Dec 3, 2020 | 07:08 PM
Reaprr's Avatar
Reaprr
i did, call one of the local transmission shops and got a doner spring 2land valve and plug for free. only other way would of been to use the sonnax oversized kit. wasn't spending that much for something will be rebuild in the next 2 years.
thanks again for the advise yall
