Cooling system issues
Old Dec 2, 2020 | 11:14 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Ramman18
I jack from the axle and use blocks if I have to.
They makes sense
Old Dec 2, 2020 | 11:19 AM
Ramman18's Avatar
Ramman18
They makes sense
I don't know how well it works though. Like I've said, it always sloshes around when taking off first thing. Isn't there a pressurized tool that shops use? How do they get air out? I've never heard of a shop jacking up one side.
Old Dec 2, 2020 | 03:51 PM
MoparFanatic21
When I worked at the Dodge Garage we did do that if we have to, but then got a machine that pushed the coolant through the system. Never used it though
Old Dec 6, 2020 | 11:31 PM
Ramman18's Avatar
Ramman18
Well, now what? The radiator came but it's got two brass bosses on it for I'm assuming a trans cooler but mine is the manual. I ordered this one "for manual trans" so I don't have any other lines out of the body. Just upper and lower hoses. All the pictures on rockauto show these brass fittings. What the heck!?!?!
https://www.rockauto.com/en/moreinfo...354137&jsn=547
Old Dec 7, 2020 | 12:29 AM
MoparFanatic21
You just don't use them. All aftermarket ones come with them unless you order a Mopar one (do they still even make them?)
Old Dec 7, 2020 | 12:49 AM
Ramman18's Avatar
Ramman18
So I can just ignore them, right? Or can I remove them from the body?
Old Dec 7, 2020 | 02:18 AM
MoparFanatic21
You can ignore them. Unsure on yours but when I tried to remove mine (while on the truck) it started leaking coolant so I had to tighten it back up.
Old Dec 7, 2020 | 07:33 AM
Yep, just leave 'em, or put plugs in 'em.
Old Dec 7, 2020 | 11:30 AM
Ramman18's Avatar
Ramman18
Ok, thanks, guys. I'm tackling it today. Sucks having to use something that isn't even as good as the old one. Oh well, this truck is about done anyway.
Old Dec 7, 2020 | 04:47 PM
MoparFanatic21
I seen on eBay they have aluminum rads for about $180
