Sinking Brake Pedal
Old Dec 6, 2020 | 12:04 AM
Spillage's Avatar
Spillage
If the master cylinder is failing, it won't lose fluid. It just loses pressure internally...
That depends on what seal is failing... if it’s the one on the end it leaks into the booster... you loose fluid but don’t see any fluid leakage.
Either way a master cylinder is in order.
Old Dec 6, 2020 | 04:26 PM
Lone Ranger Roy's Avatar
Lone Ranger Roy
Thank you again. It's tough to find a good shop with good mechanics. From everything you guys said it sounds like a master cylinder and the fact that I don't see the fluid in the master cylinder going down. I have to get under the truck and check the brake line going to the back and at the rear wheels. One good thing the truck is high enough off the ground to get underneath it without jacking it up.
Talking about jacking the truck off the ground. I have AAA I'm not sure their jack would go high enough to change a flat. I don't have the original jack that came with the truck. I think it's a bottle jack. From what I read there not that stable. Do you have any experience and thoughts on what to carry for a jack?
As always I appreciate you helping solve these problems. I thank all of you.
Old Dec 6, 2020 | 08:44 PM
I don't carry one at all. If I have a flat, I let my towing insurance take me somewhere to get it fixed/replaced. On my last truck, I didn't even have a spare tire. Now, if I am going off-road..... I have a floor jack I take with me.
Old Dec 6, 2020 | 09:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You go off road?
Old Dec 7, 2020 | 07:41 AM
You go off road?
On occasion. Sometimes, its even by choice.
Old Dec 7, 2020 | 08:10 AM
MoparFanatic21
Awesome!! I didn't think you did!!!! You just got cooler
Old Dec 7, 2020 | 08:11 AM
I own a 4x4 truck for a reason. I love to play out in the woods/fields. I try and avoid mud though....... too hard on drivetrain parts.
Old Dec 7, 2020 | 08:13 AM
MoparFanatic21
When I come out this summer I'll take you mudding! Heck we might even do some rock crawling and show up some Jeeps
Old Dec 7, 2020 | 07:03 PM
Have to drive quite a ways for any decent rock crawling around here.
Old Dec 7, 2020 | 10:31 PM
MoparFanatic21
We'll just climb the side of a mountain. A mountain is just a big rock
