oil
Old Jan 8, 2021 | 02:47 PM
horace's Avatar
horace
Default oil
My old 318s are finally using oil, been using a synthetic 13-30, stays in for 1000 mi then as it gets more miles on it oil consumption starts. All they have for non synthetic is 5-30. What do you guys think??? THX
266,000 & 216,000
Old Jan 8, 2021 | 07:31 PM
Don't the engines actually call for 10W30???
Old Jan 9, 2021 | 07:49 AM
Moparite's Avatar
Moparite
Don't use synthetic on a tired motor. Synthetic has a smaller molecule witch can help lubricate but it also can leak more. 5W-30 is for low temps up to 32* 10W-30 is for normal use. But if you have a tired motor you can use a thicker oil.
Old Jan 9, 2021 | 10:00 AM
00t444e's Avatar
00t444e
Use 15w40 diesel oil.
Old Jan 9, 2021 | 10:54 AM
2bit's Avatar
2bit
MOBIL 124403 {#120431} Mobil Super; Synthetic Blend; SAE 10W-30; 1 Quart Info
$1.95
MOBIL 124406 Mobil Super; Synthetic Blend; SAE 10W-30; 5 Quart Info
$8.79
Rockauto has a great deal on Mobil right now.
Old Jan 9, 2021 | 10:55 AM
$1.95
$8.79
Yeah, but shipping is horrendous....... probably cheaper to just pick it up locally.
Old Jan 9, 2021 | 11:22 AM
Ramman18's Avatar
Ramman18
What the heck is 13-30 oil???
Good grief, oil is everywhere. Use 10w30 or 10w40. I've used the diesel oil but the engine is louder. 10w40 is the sweet spot for summer and 10w30 for winter. Oh, and my engine has burned two quarts since it was nearly new. Don't worry about using oil.
270,000 miles
Old Jan 9, 2021 | 11:59 AM
2bit's Avatar
2bit
Order 4 or 5 of the 5 quart jugs and filters
BOSCH 72137WS {#72137} Workshop Oil Filter Info
$2.96
then shipping is pretty cheap. Even with only enough for 1 oil change with shipping it's cheaper than buying it locally, It's $16 at walmart or $6/qt at napa
Old Jan 12, 2021 | 08:09 PM
horace's Avatar
horace
I want reg oil not syn for my aging truck, wondered if should go w 5-30 because it's what they have besides syn. I"ve like my oil chg place & don't want to do it myself. So, looks like I'll try a diff place for the 97s w 10-30 Thx
Old Jan 13, 2021 | 06:49 AM
Moparite's Avatar
Moparite
BOSCH 72137WS
That's the small filter, Don't use them. Use the fram PH8A style filter it's the long style(holds more oil and about twice the filtering).
