clutch kit help please
Old Jan 13, 2021 | 02:53 PM
colehart's Avatar
colehart
Default clutch kit help please
so looking to replace my clutch in my 2001 ram 1500 5.2 manual 5 speed. i looked online at rockauto and they have about 4 different sizes. i was wondering if anyone on here knew what size might be in my truck. i dont want to take it apart to messure then wait a week while its tore apart for my clutch kit to show up.
thanks for any help.
Old Jan 13, 2021 | 02:59 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The only two sizes should be 12 something and 13 both will work for your truck. I just looked like like they have 11 and 12 1/8 either will work
Old Jan 13, 2021 | 10:04 PM
Ramman18's Avatar
Ramman18
Get the 12" kit. I recommend OEM Sachs. My second one was 11" but the third I went with the upgrade (the 12" was an upgrade on 3rd gens with the NV3500 and later trickled down to 2nd gens as required replacements).
The 12" kit has more springs versus the 11" and this aids tremendously in felt engagement. First to second gear is much smoother than on the 11" stock size. Happy shopping.
Old Jan 14, 2021 | 01:07 AM
colehart's Avatar
colehart
Default clutch kit
so would i have to do anything with the fly wheel? can anyone post a link to a clutch kit they would recommend for my truck.
Old Jan 14, 2021 | 09:34 AM
Doesn't hurt to have the flywheel resurfaced, provided you can find someone to do it, in a timely fashion.... otherwise, just scuff the surface (non-directional) with some 80 grit sandpaper......
Old Jan 14, 2021 | 10:01 AM
Ramman18's Avatar
Ramman18
I don't know where you saw four sizes, there's only 11 or 12". And 13" are not for the 3500s. This is the exact kit I have. Notice the amount of springs versus the popular Luk. I prefer the OEM brand, Sachs.
https://www.rockauto.com/en/moreinfo...354137&jsn=567
And flywheel (notice the size still says 11" but it's the same for 12"):
https://www.rockauto.com/en/moreinfo...354137&jsn=574
Old Jan 14, 2021 | 12:50 PM
colehart's Avatar
colehart
so if i get the 12in kit will i have to get a fly wheel or can i just keep the stock on in and install new clutch kit.
Old Jan 14, 2021 | 03:06 PM
Use the stock flywheel.
Old Jan 15, 2021 | 12:52 AM
Ramman18's Avatar
Ramman18
Flywheels are all the same. If yours has any cracks or bad burn marks, replace it. After the first two clutches, I replaced mine. Just be careful, they are heavy!
