my 2001 ram 1500 5.2
Old 01-14-2021, 05:02 PM
colehart's Avatar
colehart
colehart is offline
Default my 2001 ram 1500 5.2
i picked up this ram 1500 with the 5.2 5 speed manual. it only has 105,000 miles.i only payed 3000 for the truck. wondering whats the biggest tire i can fit on it with out a lift kit. also wondering what kind of after market parts i can add to it to get it louder and more power. also not wanting to empty my bank account doing so.
thanks for any help
Old 01-14-2021, 11:57 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
thanks for any help
33 is the biggest tire.
Shorty headers, aftermarket cat back exhaust at least 2.5, and a tune. If you can do the work I would recommend a cam before the tune but will need a tune to run the cam
Old 01-15-2021, 12:43 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Dang, I'm jealous! You'll love it! Mine's still kicking after 21.5 years and 270k.
Best thing to do is a Cat-back system and KN drop in filter. The rest is just bragging rights. I'm on my third exhaust and just installed the cat-less Jegs Ypipe with a straight pipe and glass pack. She roars now!
And yeah, I fit 285s on stock wheels before I even lifted it. But I've seen several trucks sporting 295s on stockers so that's possible as well.
I've lived with this truck as a daily driver for 20 years now and have replaced or fixed everything at least once except the drivetrain. Anything you need, just ask.
Old 01-15-2021, 07:45 PM
colehart's Avatar
colehart
colehart is offline
thanks.. ill look into it.. it has aftermarket duel exhaust right now, but i want more tone, i was thinking true duel exhaust.
Old 01-15-2021, 08:16 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Don't waste your time with true duals. You'd need headers, x pipe, special mountings, custom sensor welds, and a tune. Just swap the muffler itself with a different one. Look at Flowmaster's site. There's tons of options from mild, moderate, and wild.
Old 01-15-2021, 08:30 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
Don't need a tune with just exhaust mods. Doing things like the cam, or better heads, then you would need a tune.
Old 01-15-2021, 09:28 PM
colehart's Avatar
colehart
colehart is offline
oh ok... yeah. i was looking at flow master 40's. i hear its kind of rare to fine the ram 1500 5.2 in a 5 speed. any truth to that?
Old 01-16-2021, 10:54 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Might not need one, but if you're doing headers and true duals, you will want one. Every time I've altered my exhaust, it runs different and mileage changes. Especially when I removed the cat. If you're going that deep, I would look into one that can maximize those changes.
Old 02-22-2021, 12:38 PM
colehart's Avatar
colehart
colehart is offline
Default fluid change
so i changed my transfer case oil and when i drained it only about half a quart came out of it which i can only assume is bad.. i filled it and it only took about a quart and a quarter. so also i was wondering i have a manual transmission and noticed there is another drain and fill plug on the transmission, what would that be for?
Old 02-22-2021, 01:21 PM
Exactly what you would think. Drain and fill the trans. I don't recall what fluid they take though. T-case is a separate entity from the trans. They don't share fluid.
Quick Reply: my 2001 ram 1500 5.2
