Adjustable track bar
Ran into another problem with the truck last week. I put on longtube headers. I have a 2 inch leveling kit with the stock track bar. So the front end is shifted to the drivers side enough that when I go into a right hand turn the front driveshaft will just contact the header. I bought an adjustable track bar that came yesterday and it’s is missing parts and it’s not made right. It has adjustable ends on both sides but both are right hand thread so no way to adjust while it’s on the truck. I looked at a spohn bar but wondered what everyone else is running with leveling kits.
https://www.spohn.net/shop/1994-1999...2500-3500.html
Spohn has been around just this side of forever. I became familiar with them back in the 90's, with my third gen Firebird.... (they still make suspension parts for them as well.) They use good materials, and that translates into making good stuff. I think the trackbar you are looking at there will be great. No idea about the longevity of the joints, (as they are exposed) but, they are also rebuildable..... For the money they are asking, I think that's a winner. (and will likely tighten up your steering as well. )
Not sure how I feel about the steering box brace..... especially if you off-road regularly. The one that ties to both sides of the frame is rumored to put excessive side-loads on the pitman shaft on the steering box..... Now, I haven't heard of any failures related to that, or even seals going bad faster than expected..... so, maybe its just paranoia.
I use the Solid Steel adjustable track bar and relocation bracket (http://www.solidsteel.biz/trackbars.htm). It's extremely well made and has poly-urethane bushings on each loop end of the bar. The track bar will outlast the truck. I also run Spohn control arms with poly-urethane bushings on the truck and those have worked out well.
Trending Topics
