2002 2500 4x4 knuckles
#21
So I got them off. I used a three way combo. Using the trucks steering, a torch and a hub remover from Amazon ($140). I heated the knuckle up a bit then had my son turn and hold the wheel as I whacked the hub remover with a 3 pound mallet. Took me about 1/2 hour each side. I had tried each way individually prior to doing all three. Doing it together is what it took. FYI, all the lube in the world never made it inside. Dry as a bone at the flange.
Now on to the axle shaft u-joints, ball joints and reinstalling it all.
Thanks all.
Thanks all.
#22
Thanks all.
Thanks all.
You can hook onto the wheel studs and push on the stub axle and it just pushes on the center pin in the carrier.....I was a little worried about damaging the center pin but it appeared completely indifferent (changed gear oil so had cover off). However the u-joint causes the knuckle the want to "flop" front or back, so it's difficult to maintain a straight line pull.
Either way sounds like yours was much worse than mine (I'm nowhere near the rust belt), so good job!
