‘98 Ram 1500 engine noises
Old Feb 17, 2021 | 01:21 PM
chrisfort123092's Avatar
chrisfort123092
Default ‘98 Ram 1500 engine noises
I have a 1998 1500 4x4. I just replaced all the steering linkages and the steering gear box. Prior to, I had a slight ticking while accelerating and it still does. But now it also has almost a grinding/clunking sound while accelerating. The new sound is mostly when the RPMs are between 1700 and 2200. But as soon as I release the pressure on the gas pedal the ticking and grinding/clunking noise all stop. Anyone have any ideas?
Old Feb 17, 2021 | 01:48 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Did you install the transfer case saver?
Old Feb 17, 2021 | 01:58 PM
2bit's Avatar
2bit
I would suspect dry u-joints.
Old Feb 17, 2021 | 02:23 PM
chrisfort123092
I honestly don’t know what that is. The engine was replaced and the transmission was rebuilt before I bought the truck. It has three slight tick when I bought it but the other noise wasn’t there before replacing the steering linkages
Old Feb 17, 2021 | 02:24 PM
chrisfort123092
I regreased everything after it was all installed.
Old Feb 17, 2021 | 04:56 PM
T-case saver.
Old Feb 17, 2021 | 05:50 PM
Moparite's Avatar
Moparite
Did you do the wheel u joints? Also check the ones on the rear drive shaft.
Old Feb 17, 2021 | 06:29 PM
Ramman18's Avatar
Ramman18
Check the rear drive shaft ujoints. They like to make noise in one direction and not the other when worn out.
Old Feb 17, 2021 | 08:57 PM
chrisfort123092
I’ll have to check the back u joints and I’m going to order the t saver this weekend. Thank you!
