Need help! 2001 Dodge Ram 3500 4x4 grinding/Vibration at 70mph
Old Mar 22, 2021 | 10:03 AM
Troy Gipson's Avatar
Troy Gipson
Default Need help! 2001 Dodge Ram 3500 4x4 grinding/Vibration at 70mph
New here guys! I have searched this all over and not coming up with anything. I have a grinding/vibration noise at 70mph.You slow down the noise goes away 60-65. You go 70 and turn right and left and the noise stays the same pulled front drive shaft same issue pulled driver axle and same issue. New transmission rebuilt t-case new u joints and carrier on rear driveshaft. 2 new front wheel bearings. Ball joints are good. I can feel it in my floor board. Any help would be nice I am lost
Old Mar 22, 2021 | 01:57 PM
Think I might take a peek at the snap-ring that holds the output bearing in place on the rear shaft. It's cleverly concealed by the tailhousing of the t-case..... gotta drop the rear shaft. I know it was just rebuilt..... was the noise there before the rebuild? If it was, I might be looking at the pinion bearings in the rear diff.
Old Mar 22, 2021 | 02:17 PM
Troy Gipson
I have drove it 600ish miles since the t-case was rebuilt I’m not exactly sure where the snap ring is that you are talking about? Have I missed anything on the front end that could possibly be doing it?
Old Mar 22, 2021 | 02:59 PM
Snap ring is on the output shaft of the t-case, right behind the main bearing at the back of the case. Basically, right where the parting line between the back half of the t-case, and the tailshaft housing is.
If the noise doesn't change when turning left/right, I don't think it's in the front end.
