Rear axle stuck
I have a 2000 Dodge Ram 1500. 4x4. Rear passenger side seal leaking. I went to pull the axle and had to actually hit it with a hammer because it wouldn’t budge to remove c clip. Now I can’t remove axle have tried a slide hammer all that did was make my hands sore. Driver side rear removed fine. Any suggestions appreciated.
Can you tell where it's hanging up at? So far as I know, the only thing holding it in is the c clip. Even if it was hung up on the outer bearing, I would think the slide hammer would have pulled it, bearing, seal, and all.
I think at this point, I think you should remove the carrier retainer clamps n loosen the carrier adjuster of the offending side. Count the amount of turns because you'll have to put it back there. If the carrier is stuck, this'll loosen it so you can get the c-clip out. Hope it helps.
I spent over 3 hours with slide hammer and hitting it with pb blaster. I was only able to get it to move out about 1 inch.
It looks like the seal came out a bit ? That would mean the bearing is trying to come out as well. I can't really come up with any reason why the axle wouldn't slide out short of the bearing having failed catastrophically and something is friction welded to the axle shaft.
Trending Topics
I'm hesitant to jump in here as I'm definitely NOT a gear man. I have seen bearing get stuck from heat and pressure and burn a groove in the axle. The beari will be stuck and you may need a REALLY big sliding hammer.
Yes, but it's going to more difficult. Typically the bearing is pulled out with equal force on two points 180 degrees apart. In your case it may well be that the bearing race ends up wedged in its seat. What I would try is slide hammer two, three times, then push the axle shaft back in until it spins freely and turn it 180 degrees and slide hammer again. Then turn 90 deg and repeat 180-90-180-90 you get the idea, only small movements every time.
It would help if you can pry the seal out and remove it so you can maybe get a look what's happening there.
