V10 Ram Swap into a 1970 Plymouth
Old Apr 30, 2021 | 10:10 PM
  #21
monc440's Avatar
monc440
Just picked up this stock V10 I will be using as my starter engine. Picked it up on CL Chicago for $450, 100k miles with the trans, all the accessories, computer, all the power train and under hood wiring. Came out of a 2500 that was hit in the rear and totaled.
Old May 1, 2021 | 10:42 AM
  #22
What year did it come out of?
Old May 1, 2021 | 10:09 PM
  #23
monc440's Avatar
monc440
Feb 1996 according to the tag on the engine.
Old May 2, 2021 | 10:16 AM
  #24
Cool, that should make life easier.
Old May 6, 2021 | 10:38 PM
  #25
monc440's Avatar
monc440
Started making the oil pan. The stock truck pan is a rear sump and the C body is a center sump. I decided to cut and section the stock 383 pan onto the truck pan. The V10 has a 7qt oil capacity so after I get the main section made I will add a section to the sump to make it deeper.
Old Jun 26, 2021 | 11:19 PM
  #26
monc440's Avatar
monc440
Finally got back to work on the Plymouth. I got the oil pan and pick up tube made.
Old Jun 26, 2021 | 11:21 PM
  #27
monc440's Avatar
monc440
I tried to install the engine and trans together but didn’t have enough clearance.
Old Jun 26, 2021 | 11:26 PM
  #28
monc440's Avatar
monc440
I got the engine and trans installed. Fits like a glove 3/8 inch at the steering gearbox and 1/2 inch at the upper control arm on the passenger side.
Old Jun 27, 2021 | 09:33 AM
  #29
Gonna have to pull the motor to change spark plugs?
Looks good.
Old Jun 27, 2021 | 10:00 PM
  #30
monc440's Avatar
monc440
Looks good.
No it sits high enough I can get to them easily. Easier than doing it in the old truck. The engine compartment in the old c body is big. I actually got lucky because when I mocked everything up I didn’t put the exhaust manifolds on.
