Help ID’ing rear differential
Old May 12, 2021 | 07:21 PM
Machine71's Avatar
Machine71
Default Help ID’ing rear differential
Hi, this is on a ‘98 2500 4x4, #8800 gvw version. Time for a pinion bearing and seal.
im pretty sure it’s a Dana 60 but I’m not positive. Of course the tags are gone and there isn’t a “60” or “70” cast into it.
There is a number “248 48543” cast into a web, but I can’t find out what that means.
thanks for any help!
Old May 12, 2021 | 07:41 PM
If you have the 5.9 gas, its a dana 60, if you have the diesel, its a d70, same for the 8.0.
Old May 12, 2021 | 07:46 PM
Machine71's Avatar
Machine71
Ha! I knew I’d forget a pertinent piece.
5.9 Gas, thanks for your help!
Old May 13, 2021 | 11:40 PM
DerTruck's Avatar
DerTruck
Fun fact: Chrysler called the D60s 248RBI (rear) and 248FBI (front). No idea why
Old May 16, 2021 | 07:38 AM
Machine71's Avatar
Machine71
Found that in the shop manual. It's Rear and Front Beam-design Iron axle housing. Why they didn't just call it a Dana 60 like you say is beyond me too.
I like to imagine it's for the same reason they call the drive shaft a Propellor Shaft, because the guy who wrote the manual was an old school engineer type with a white button down pocket shirt and horn rimmed glasses like Michael Douglas in Falling Down.
Old May 16, 2021 | 09:39 AM
Likely a fair bit of truth in that statement.
Old May 18, 2021 | 12:32 PM
Charles Carter's Avatar
Charles Carter
Good to know that. I was just under my rear end getting the #s to figure this out...I have a 448 code. That would be the Dana 70, correct? Mine’s a ‘99 2500 Cummins. I also need to perform a pinion seal change.
Old May 18, 2021 | 03:26 PM
The diesel got the 70 if auto trans, 80 if manual. (but, they may have just been in the one ton trucks...)
