My transmission to transfer case flange broke..
Old May 25, 2021 | 05:38 PM
  #21
Ramchie's Avatar
Ramchie
Sounds like I need to pry harder. Going to stick a rod in between shaft and diff and Rachet it. If that doesn't work its cutting time..
Thought about taking a torch to where it pinches those 'bolt heads' (the yoke?). Real close to the fuel tank though
Old May 25, 2021 | 05:52 PM
  #22
Yeah, four bolts, two straps, and pry the joint out of the yoke.
Old May 25, 2021 | 05:56 PM
  #23
Ramchie's Avatar
Ramchie
I got it man! Wasn't gonna let it beat me lol. Took some excessive hammering..
in guessing this happened because of the orientation it came out? Or too much banging. Either way it's out. More pics coming.
THANK YOU
Old May 25, 2021 | 06:01 PM
  #24
Yeah, save that cap, and watch out for the little rollers in there. Looks to be in serious need of some grease. Or replacement.....
Will the shaft pull easily out of the t-case now?
Old May 25, 2021 | 08:02 PM
  #25
Ramchie's Avatar
Ramchie
yessir! Pulled right out and smashed my fingers real good.
I didn't realize those little caps came off like that.. was thinking something was really f'd up at first.
Okay next step find that part at a pick a part or online.
Old May 25, 2021 | 08:04 PM
  #26
Is it a separate part, or is (was??) it part of the overdrive housing?
Old May 26, 2021 | 03:58 PM
  #27
Ramchie's Avatar
Ramchie
I was wrong thinking it was some little flange, yes haha . It must be the overdrive housing that broke, technically part of the transmission? Pictures incoming. I guess I need to get that overdrive housing out, and replace it.
Looks like it won't be too much trouble to replace it at this point. But where to find it...
https://dodgeforum.com/forum/2nd-gen...e-housing.html
Looked at this thread from 2011. Recommends https://www.wittrans.com/parts. I guess I will give them a call, I cannot find the part on rock auto. I'm sure it's at least listed, even if it is out of stock. Is it called anything besides the o/d housing?
Also I put up a picture of that support arm thing coming down. I'm wondering how likely it is that it is the source of the issue? Looks like it is supposed to offer some flexible support, could be it's so rusted it was keeping it too stiff? Just a thought
Old May 26, 2021 | 04:05 PM
  #28
Normally it doesn't come separate. Comes as part of the whole transmission. Could likely find on in a yard around you somewhere..... IF they will sell it to you without the rest of the trans.
Also, keep in mind, looks like yours is 97 or older, and the 4x4 shifter mounts to the trans, so, 98 and up housings won't work, as they don't have provisions for that.
Old May 26, 2021 | 04:45 PM
  #29
Ramchie's Avatar
Ramchie
I'll start looking
Thanks for the heads up.
Just curious. I have another 2nd gen 1500. It was kept in better shape by previous owners. Its my daily now. All this to say-
How much would you sell a rusted up single cab with a 'cracked' overdrive housing and a Jerry rigged exhaust system. 170k miles, dash and interior are in great shape.
getting some $1000 offers I'm turning down.
Thanks for all your help per usual. Keeping the second gens on the road
Old May 26, 2021 | 06:05 PM
  #30
Ramchie's Avatar
Ramchie
Pics aren't real clear, but, it looks to me like the back part of the trans broke, and is still attached to the t-case? If so, you can just replace the O/D section of the trans, and call it good.... but, I would be nervous about that. Would be more inclined to replace the entire trans....
Just realized what you meant by O/D here. I was thinking outside diameter section, what? Haha, gotta learn to read more carefully
You had it pinned down day one. Thats what I get for not asking questions.
