Mystery Wiring harness
Old May 30, 2021 | 08:41 PM
94dodgeIDI's Avatar
94dodgeIDI
Default Mystery Wiring harness
Hey I have a 1994 dodge ram 2500 4x4 v10 auto chassis with highline and power seat etc and wondering what theese 4 harnesses do? They have tons of wires coming out of them and wondering if they are factory add on harnesses?
Old May 30, 2021 | 09:00 PM
Connectors for options you don't have, or, junction blocks in a couple instances.
Old May 30, 2021 | 09:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Blue one I'm unsure about, the other ones are junction blocks. Used to make a connection in the plugs, a weird thing Chrysler did
Old May 30, 2021 | 09:52 PM
94dodgeIDI's Avatar
94dodgeIDI
I'd really like to know what the blue one does a sit looks like a proper plug I can understand the junction blocks now, but the blue plug has been hanging there as long as I've had it
Old May 31, 2021 | 12:40 AM
MoparFanatic21
Trailer brake controller?
Old May 31, 2021 | 12:47 AM
DerTruck's Avatar
DerTruck
The blue plug is the ABS/Airbag diag connector. The other ones look like the infamous Chrysler "joint connectors", aka glorified splices.
Old May 31, 2021 | 12:51 AM
94dodgeIDI's Avatar
94dodgeIDI
THANK YOUU! My ABS light is on and I have an idea what it is but would like to make sure I'm gonna look for the pin out to see if I can jump read it or does that require a special machine like I've heard 🤔
Old May 31, 2021 | 01:07 AM
MoparFanatic21
I think you need a scanner. Can't do the pin truck with OBD1 I THINK
Old May 31, 2021 | 01:20 AM
94dodgeIDI's Avatar
94dodgeIDI
I remember a video about it but I'm not sure how said something about a black wire?
Old May 31, 2021 | 01:44 AM
DerTruck's Avatar
DerTruck
Grab the FSM from here. Page 5-28 talks about "grounding the diagnostic connector" to get the ABS light to flash but I think they talk about the service connector near the ABS module which is different from the data link connector. Why make it easy ..... Anywho the connector has only a single black wire so you're remembering it right.
