TC locking and unlocking...rpms goin up high
Old Jun 2, 2021 | 07:58 AM
Ram Rod 97's Avatar
Ram Rod 97
Link works for me..... Download the manual for your year truck.
Can't post videos here. Need to upload it to someplace like youtube, then link to it here.
alright my tv cable seems fine
there’s the link
Old Jun 2, 2021 | 08:02 AM
Why is the check engine lite on? Doesn't look like it is even making it to O/D..... seems it can't make up it's mind between second, and third?
Old Jun 2, 2021 | 08:08 AM
Ram Rod 97's Avatar
Ram Rod 97
o2 sensor is the only code. Hot or cold it drives about the same
Old Jun 2, 2021 | 08:16 AM
Have you replaced any of the electronics in the trans? Or the trans itself???
Old Jun 2, 2021 | 08:22 AM
Ram Rod 97's Avatar
Ram Rod 97
trans was suppose to have been rebuilt when it was in limp mode it had a gov pressure code but it was stored code. But hasn’t thrown a trans code since. I haven’t touched the trans besides checking fluids and yes I’ve changed TPS
Old Jun 2, 2021 | 08:30 AM
Ram Rod 97's Avatar
Ram Rod 97
also as a side note the trans shifted fine before motor swap and all the wires to the trans look fine and are plugged in
Old Jun 2, 2021 | 11:15 AM
AtomicDog's Avatar
AtomicDog
I'd suggest getting up under the truck and checking to make sure your TV cable linkage is properly connected to the transmission, since it was recently rebuilt. I found after a trans repair that my TV cable linkage had popped off the valve body shaft (bolt wasn't tightened properly), so it looked like all was well at the engine, but the TV cable wasn't doing anything at the transmission. There is also a spring that keeps tension on the TV cable that's installed at the transmission, too.
