Ram 2500 Cummins Transmission wasn’t supported nv4500
Old Jun 2, 2021 | 08:48 PM
Clayton wheeler's Avatar
Clayton wheeler
Default Ram 2500 Cummins Transmission wasn’t supported nv4500
So I took the rear cover off of the transmission and of course I had to jack it up for that, but since I wasn’t able to fix it the day I had it apart I had to leave the jack supporting it for a day and a bit, and the jack ended up dropping at some point, just wondering if I screwed up the motor mounts or if it should be fine
Last edited by Clayton wheeler; Jun 2, 2021 at 08:52 PM. Reason: Forgot to say it was a diesel
Old Jun 2, 2021 | 08:49 PM
I would be more concerned about the distributor and cap.
Old Jun 2, 2021 | 08:52 PM
Clayton wheeler
Oops sorry I should’ve specified it was a diesel
Old Jun 2, 2021 | 09:02 PM
Don't have to worry about the distributor then. No idea where the injection pump is on those, or what else might be on the back of the motor. As that is likely what was supporting the rest of it. It would hit the firewall, and stop..... Take a look around with a mirror. If you don't find anything damaged, I suspect you will be fine.
